You can add multiple NR sides by using the Termination Points (TP) IP address from the MN side.
For example, just as you create an X2 interface between MNs, you can establish an Xn interface between the MN and SN using the Termination Points IP address.
In NSA mode, a 4G site can connect to multiple 5G sites, and conversely, a 5G site can connect to several 4G sites. So neighbors are needed to be defined between 5G cell and several 4G cells.
