Hello experts,
I hope all are doing just fine.
I need your support. We have having a hard time in our indoor system , using Comba solution ( DAU, ACU, DEU and DPU for indoor coverage ) ,Unfortunately the rru´s are not irradiating the power in the meantime taking off the coaxial cables from the rru´s we can the site irradiating the signal.
Actually we are using connectors on coaxial cable. We have faced high VSWR alarm, but now we are working on it , and it seems fine but still no input power.
The frequency band for 5G is 3500 Mhz.
Can you please suggest anything will should do in order to fix that??
Thanks in advance.
