Do you have comments about Nokia ABIO capacity unit?
- How many is needed for any secor for example for 3 sector node how many is needed?
- Does it support just 5G or supports previous technologies?
I think 1 ABIO is ok for 3 sector site and it will support 5G.
Let’s wait more responses.
How many maximum ssb beams Nokia support? | 4 | 650 | January 22, 2022 | |
Single gNB per sector or only one per sector | 1 | 452 | July 3, 2023 | |
Does Nokia RRH unit support single fiber SFP? | 1 | 441 | December 23, 2022 | |
Question about 5GNR RedCap supported antennas | 1 | 701 | February 18, 2023 | |
4x4 virtual antenna in Nokia | 7 | 1032 | March 17, 2020 | |
Vendors support for 5G NR UL 256 QAM | 3 | 406 | July 15, 2021 | |
5G MU-MIMO in Nokia system | 8 | 888 | May 6, 2023 | |
Nokia DL MIMO Mode and NR Cell Type features | 1 | 468 | September 4, 2023 | |
Moran/mocn | 3 | 1786 | May 17, 2020 | |
Number of DU supported by CU | 2 | 450 | June 6, 2021 |
