Hi Guys,
I want the IP of my address of my laptop to be in Trusted list in Nokia Airscale BBU. So that below alarm should not be send for if the connection is from the Trusted IP list no matter by how many times that the user opened via SSH or the WEB. I can see the threshold max of 100 but is it possibile do like what i mentioned above…–>Adding the laptop ip to trusted ip list so that it would bypass the Userevent or any other methods.
Alarm = 61008 User Event Temporary Buffer Over Threshold
P_C
1
Related Topics
Nokia GSM Abis over IP PCAPs | 2 | 1160 | April 18, 2022 | |
Any Alternatives of Nokia NetACT? | 17 | 1641 | November 30, 2023 | |
Interpret AirScale Alarm to match real exisiting alarm | 0 | 1074 | February 11, 2022 | |
Contact Detection Project | 24 | 963 | June 6, 2020 | |
Is there any way to capture the angle of arrival (AOA) in 5G /4G? | 3 | 291 | February 1, 2023 | |
How to tell from traces if the user is being served by 5G NSA or 4G in Core? | 3 | 242 | April 17, 2024 | |
How to login in the BSC via NWI-E ericsson | 1 | 575 | September 22, 2023 | |
Check IUB traffic with TWAMP protocol, with KPIs | 2 | 731 | November 26, 2020 | |
PDH interface related counters | 6 | 302 | January 13, 2023 | |
Boda lite - 5G Ericsson Parameter baseline audit | 3 | 1998 | June 16, 2024 |
