Hello Everyone.
Can anyone assist me with Nokia handover/attempt neighbor counters? Specifically, how can I fetch these counters along with the source and destination details? Which counter should be used for this purpose?
Thank you for your support!
raheel
January 17, 2025, 8:20pm
2
Which technology are you referring to?
raheel
January 17, 2025, 8:21pm
4
If you have access to Nokia NetAct under 4G, there is a default report, RSLTE0031 , available under the mobility section. Using this report, you can download per-neighbor KPIs.
Is a similar per-neighbor dump available for BSC/RNC in NetAct?
If yes, could you kindly share the report ID?
raheel
January 17, 2025, 8:22pm
6
Yes, it is available in the dump for created neighbors as well.
For example:
4G to 4G :
Use the lnadj table for site-to-site data.
Use the lnrel table for cell-to-cell data.
4G to 3G :
Use the lnadjw table for site-to-cell data.
Use the lnrelw table for cell-to-cell data.
Sorry, but I couldn’t find any predefined GSM-GSM or GSM-WCDMA per-neighbor reports.
Could you kindly explain how to create such a report, if possible? Your guidance would be greatly appreciated.
raheel
January 17, 2025, 8:24pm
8
Are you referring to reports in NetAct or from the dump ?
NetAct.
I need the neighbor handover attempts and successes of cells in the BSC for a specific day.
I recall seeing a report during a project in 2021.
If I’m not mistaken, the report numbers for UMTS in NetAct are 44 and 45 .
Try searching report 153 in NetAct. Shows NBR HO Attempts and Fails for a fixed period.
