I am considering why the NR DSS Coverage (SS-RSRP…) is lower than LTE DSS Coverage with the same configurations (long, lat, tilt, azimuth, band…)?
Our EN-DC band combination is: b3+n1 (DSS: LTE + NR 2100)
Does anyone have an idea for this case?
Thank you in advance!
Hi Tony,
I assume you are using same antenna, same EIRP, as seen in your responses before…
Have you ever compared your LTE B3 to LTE B1, as I believe the difference of 1-2 dB is obvious with band path loss difference. This difference will obviously exist for ENDC B3 and NR n1 as well.
Hope you compare coverage from both LTE and NR DSD co-located cells only…
Besides this, am not sure what is your LTE anchor strategy for this DSS…having LTE CRS port (mapped to PCI) conflict with NR PDSCH will also deteriorate your NR DSS performance in terms of quality (if you plan your LTE anchor to other than co-located as well)…anyway, it should not impact coverage.
