Number of HARQ processes in LTE/5G in DL/UL
Hi All,
For LTE in UL there are 8 harq process for tm1 and 16 for tm2.
And for LTE in DL there are 8 harq process.
For 5G in UL there are 16 harq process per cell.
And for 5G DL as well 16 harq process number.
Any correction required?
Please check :heavy_check_mark: experts
LTE has only max of 8 HARQ process either for DL or UL or regardless of TM.
I’ve seen for the Uplink, LTE Advance Carrier Aggregation it is 8 per serving cell (transmission mode 1) and 16 per serving cell (transmission mode 2).
Thanks for sharing, I will check UE logs to see.
As per my knowledge, LTE has 8 HARQ process for DL or UL.
I never seen process ID >8 in logs .
Could you please share the log snippet where you have seen HARQ process till 16 w.r.t TM mode as well.
Thanks !!!
So, is number of harq processes in UL and DL same or not?
It is 8 in LTE and 16 in NR.
Is that for UL and DL?
It’s same in UL and DL.
In other releases it may be increased as well.
https://www.3gpp.org/ftp/tsg_ran/WG1_RL1/TSGR1_102-e/Inbox/drafts/8.4.3/R1-200xxxx%20Summary%20of%208.4.3%20on%20HARQ%20for%20NTN_v018_Eutelsat.docx
