Hi all.
Does anybody know of any NV to enable ‘CRI_RSRP’ reporting on the x55 chipset?
I see UE send reconfig failure if this is asked from it.
Other report quantities are working fine.
Hi all.
Commercial UE with x55 chipsets for SA testing | 1 | 482 | June 26, 2020 | |
For TM9 does we consider CRS or CSI-RS ports? | 1 | 333 | July 28, 2021 | |
NV item to disable IMS on QC chipset | 1 | 1148 | May 1, 2021 | |
Failures on RRC level for SA NR | 2 | 503 | October 17, 2022 | |
Command to check RET from RRU | 6 | 1391 | March 17, 2021 | |
How can I check if ecgi measurement is enabled in ANR? | 0 | 464 | October 7, 2021 | |
5G NSA RE Power check using drive test | 2 | 557 | April 6, 2023 | |
How to check the channels number related to a PRI pilot numbet in AGCF? | 1 | 53 | July 27, 2024 | |
How to check from Logs if SRB3 is implemented in network? | 6 | 540 | June 6, 2021 | |
How to check which UEs are supporting DSS? | 4 | 588 | March 15, 2021 |
