|| NWDAF - A Perfect AI ML and Analytics recipe for E2E Network Automation for 5G & 6G ||
To understand better, lets go technology wise…
> 4G / LTE → No Analytical component in Core Network.
> 5G SA → NWDAF in 5G was introduce as AI – ML / Analytical component for all the NFs. NWDAF for 5G SA, is a AI-based network data for intelligent and autonomous network operation and service management. NWDAF means Network Data Analytics Function.
NWDAF Components = Data collection + Message framework + Logical analysis + Machine learning, and storage
NWDAF Task = It collects data in the 5G core system, analyzes trends, and performs future predictions based on Machine Learning (ML).
NWDAF Limitation as on date = As 5G will have 100s of NF’s and collecting data from 100s of NFs and analyzing it – puts limitation on accuracy / time to give feedback about the issue / High processing time.
Solution = Deploy multiple Local NWDAF and then orchestrate together at central unit.
> 6G → Based on the limitation in 5G, NWDAF in 6G was introduce for each NFs as AI – ML / Analytical component. (Ref. the image below)
Role of Intelligent plane = Information from all Network layers or Other Core Components / Other Technology components is collected + Logical Analysis + AI / Ml based data learning will be performed with ultra-low latency across the entire network area. Additionally, AI-based analysis and inference results are shared through the intelligent plane to ensure high reliability.
Use of Intelligent plane = Parameters and Network configuration information that were previously managed statically for each NF’s are now dynamically auto-configured and optimized.
To read more in details visit below link… Follow me for more updates…
Share with colleagues …Feel free to Add… Comment… Suggest…
