On which condition N3IWF or UE perform the create_child_SA Rekeying procedure?
* N3IWF (Non-3GPP Interworking Function) is a function in 5G that connects untrusted non-3GPP networks to the 5G core.
After tunnel break and reconnect.
And during amf relocation or ho.
Re-connect in case of TCP connection failed also?
Yes. Should be.
Okay! Thank you!
