One-glance visual that explains the entire 5G stack - from Physical to NAS Layer
5G looks complicated… but it doesn’t have to be.
Most people get lost in the layers of 5G.
So I created a one-glance visual that explains the entire 5G stack - from Physical to NAS Layer. :gear::signal_strength:
:hammer_and_wrench: What’s the problem?
Too many acronyms.
Too many functions.
And no simple explanation of how these layers interact.
:white_check_mark: Here’s the solution:
This visual gives a clear breakdown of all layers in the 5G Protocol Stack:
:small_orange_diamond: Physical Layer – Modulation, Massive MIMO, DSS
:small_orange_diamond: MAC Layer – Scheduling, HARQ, Traffic Prioritization
:small_orange_diamond: RLC Layer – Retransmissions, Segmentation, Low Latency
:small_orange_diamond: PDCP Layer – Security, Header Compression, Split Bearers
:small_orange_diamond: SDAP Layer – New in 5G NR, Maps Flows to Bearers
:small_orange_diamond: RRC Layer – Mobility, Paging, Connection Setup
:small_orange_diamond: NAS Layer – Authentication, Slicing, Emergency Services
:pushpin: Why this matters:
If you work in telecom, networking, or product management, this is your cheat sheet to mastering 5G faster.
