Hi All,
We have Huawei and Ericsson 5G.
For ANDROID we are seeing that mobile ookla speedtest is similar for both Huawei and Ericsson areas.
But for IPHONE it shows 20% lower throughput as per ookla results in Ericsson region compared to android in Huawei region.
Anyone has idea what can be reason for one of issue we are facing?
Handset level parameters setting should not effect as same thp achieved Huawei network.
But in Ericsson less with iPhone.
Variable is Network ( Ericsson)
Ok then check for CA config.
Is the operator server used or ookla autoserver.
Ookla autoserver changes servers dynamically and results might vary from region to region depending on edge ookla server availability at a region.
In that case, its may be difference scheduler performace.
Can you measure and compare iphone with Huawei and Ericsson, rf paramaters reported cqi, scheduled cqi ri… number of rbs, etc?
For LTE, I remembered iPhone had difference in CQI/MCS use than other phones.
At similar RSRP/RSRQ iPhone would calculate different (can’t remember lower or higher) SINR/CQI and use different MCS than others.
If you have data from both phones just plot SINR/CQI with MCS and see the delta.
