oRan Modulation compression for circular signals
Hi All,
I can understand oRan modulation compression for QAM levels but what about circular signals such as PSS?
Any help appreciated.
Adding further notes:
One of oRan compression techniques is modulation compression. This is lossless compression intended for downlink provided it is category B split 7.2 as I/Q are not precoded so QAM levels arrive at input and the worst case such as 256QAM can be implemented, with lower QAMs as subsets. The problem is that with non-QAM based signals such as Zadoff-Chu of PSS which is part of downlink many signal levels arrive at input. So either these are excluded from compression at extra cost or there is a solution that I don’t know.
