Hi team, do you know the oss command or cli command to get the temperature of the radios or baseband?
thanks in advance!
thanks in advance!
Hi, @Juan_Leon, if you ask about Ericsson baseband check here. Also you can use invx
/cabx
commands in amos
Ericsson command to check enabled features in 4G and 5G | 1 | 301 | April 19, 2024 | |
Moshell commands or oss tools to check user KPIs | 1 | 2903 | August 11, 2021 | |
Quick moshell command to check VSWR values | 5 | 155 | October 17, 2024 | |
Node High temp | 2 | 193 | March 5, 2024 | |
Ericsson Command For Defining 2G Cell Neighbors | 1 | 31 | September 26, 2024 | |
BaseBand Ericsson 6630 - Temperature | 6 | 2474 | November 17, 2023 | |
LAC information | 1 | 541 | July 28, 2022 | |
Command to check Horizontal and Vertical Beamwidths of antenna? | 2 | 577 | April 12, 2022 | |
User Throughput for Ericsson 3G node using Amos | 1 | 290 | December 30, 2023 | |
CSFB checking in EnodeB | 0 | 376 | August 16, 2023 |
