OSS node credentials for BSC and MSC
Dear Experts,
In our network, Node credentials for BSC and MSC are about to expire. Can anyone guide me on how to generate them in the OSS?
vendor: Ericsson
BR//
Hi, @Mani, try to set renewal parameter to automatic:
NodeCredential=1
   renewalMode=AUTOMATIC
if I understood you correctly.
Hi,
Thanks, actually I am looking for a solution on how to generate a valid certificate in the OSS for the MSC and BSC.
BR//
There are two options: automatic and manual enrollment. Both requires to install certificates from ENM, create TrustCategory, NodeCredential. Then startOnlineEnrollment or installCredentialFromUri depends on your choice.
