Output .nmf instead of .nmfs in Nemo Outdoor
Hi,
Does anybody now if it is possible to configure Nemo Outdoor 9.0 to output .nmf format logfiles (plain text) instead of .nmfs?
Thanks
It depends upon the license used by the mobile phone of NATA and NEMO handy.
If you have .NMFS license support in the phone is enabled the Nemo outdoor will create the .nmfs log file otherwise it will create .nmf.
thanks for your feedback!
HI anybody have setup file nemo outdoor 9.9.0.4?
BR
