Hello All.
Any suggestions on PDSCH booster switch ON and OFF.
Vendor is Huawei.
Hello All.
Vendor is Huawei.
Agg level will improve and CCE utility can go less but need. To CCE allocation failure KPI.
PDCCH booster i taught.
Tahnks. I have distant users in remote areas.
Whats is the switch name?
MO: PDSCHCfg
Parameter: PdschPowerBoostingSwitch
Indicates whether to enable PDSCH power boosting. If this parameter is set to ON, PDSCH power boosting for TM9 UEs will be enabled. If this parameter is set to OFF, PDSCH power boosting will not be enabled. This parameter applies only to LTE FDD.
