Is it true that in sub 6 GHz bands SRS is preferred to be scheduled periodically where as for mmWave it is preferred to aperiodic?
If yes what’s the logic behind this?
Why MIB periodicity is higher in NR compare to LTE? | 1 | 189 | December 28, 2023 | |
Is the pathloss larger at mmWave frequencies? | 0 | 468 | October 21, 2021 | |
CQI Aperiodic vs Periodic | 0 | 376 | June 28, 2023 | |
What is the reason for Analog Beam Forming in > 6 Ghz? | 2 | 416 | October 16, 2020 | |
5G mmWave loss compared to LTE low/mid band? | 7 | 475 | July 12, 2021 | |
Does mmWwave synchronization must be more strict than sub6? | 2 | 405 | February 2, 2022 | |
Criteria for choosing SSB OFDMA symbol configurations in 5G (3-6 GHz, SCS = 30 kHz) | 5 | 24 | October 26, 2024 | |
What specific inputs does the MAC scheduler consider when allocating downlink resources? | 15 | 114 | October 17, 2024 | |
Does high sub carrier reduces fading in mm compared to low subcarrier used? | 1 | 262 | June 9, 2021 | |
Difference between periodicity and variable transmission repetition periodicity in 5g? | 0 | 407 | May 24, 2021 |
