pmRrcConnEstabFailCause
Hi Dears,
In Eniq Ericsson 4G, I have this causes for RRC CONN ESTAB FAIL, does anyone can help with cause for each one?
pmRrcConnEstabFailCause1
pmRrcConnEstabFailCause2
pmRrcConnEstabFailCause23
pmRrcConnEstabFailCause24
These measurements provide the number of failed RRC establishments per cause.
You can find detailed description in ELEX.
Yes, thank you.
Also: are there any counters in Ericsson that tells you about VSWR degradation for 4G and 5G?
No counters as far as I know, you can check using invxr for VSWR values in any eNodeB.
Thanks.
Is you referring to using oss command to check the level?
Yep, you can run script using shell tool or putty and can fetch it for entire network.
cabx will give you the vswr results, no counters as other friends mentioned
Hi,
What is the exact command one should use to get the VSWR values per cell in an eNodeb?Any snapshot would ne helpful.
Thanks
