Hi experts,
What is the parameter that indicates the position of the SIB 1 in the MIB message.
Thank you.
Hi experts,
Thank you.
Thank you.
but my question is how can you calculate the position by knowing what the value should be placed.
RA-RNTI preamble | 2 | 447 | December 14, 2022 | |
How can I find the position of MIB in PBCH in SSB block? | 2 | 349 | July 25, 2022 | |
What is dedicated SIB1 in NR? | 8 | 2613 | November 8, 2024 | |
MIB broadcast info | 3 | 1487 | March 16, 2020 | |
5G pdcch-ConfigSIB1 configuration | 2 | 960 | November 25, 2021 | |
Is there any parameter that indicates CORESET with the DCI sent for the RAR message? | 0 | 428 | April 18, 2023 | |
5G NR SIB scheduling | 2 | 731 | June 6, 2024 | |
After reading MIB what is the step by step procedure to read SIB1 which is scheduled in the PDSCH? | 1 | 285 | May 27, 2023 | |
MIB and SIB Channel Mapping | 1 | 512 | August 23, 2021 | |
PDSCH Config Common Parameter Structure | 0 | 913 | October 16, 2020 |
