Could you please tell what is PRACH index value for LTE?
Or is it based on preamble ID will be assigned index value?
ABHI8171
1
ankgitm
2
Hi we have PRACH config index table which will indicate in which subframe RACH wil be transmitted.
Generally for FDD taking value 6 and for TDD 13.
Related Topics
What is commonly used value for PRACH Freq offset for LTE TDD and FDD cell? | 1 | 878 | February 23, 2022 | |
RA-RNTI in RACH of 5G SA is based on what? | 0 | 374 | June 30, 2021 | |
How exactly Preamble sequence transmitted using frequency and time resource? | 0 | 343 | March 31, 2023 | |
Which is commonly used PRACH format for FR1 and FR2 for 5G network? | 2 | 645 | March 26, 2021 | |
How is RACH density configuration is decided for a cell? | 1 | 346 | September 1, 2023 | |
Suggestion for RACH optimization in 5G NR, NSA | 3 | 1187 | August 19, 2024 | |
Resource grids for 5G-NR showing time frequency and the different channels | 2 | 278 | May 20, 2023 | |
Filter coefficient for LTE intrafrequency not mentioned in any RRC reconfig message | 0 | 363 | July 30, 2022 | |
De-(multiplexing) in LTE MAC | 0 | 448 | February 27, 2021 | |
Changes Parameters Effects About Paging and Initial RACH Success Rate | 0 | 497 | September 9, 2021 |
