Dear brothers.
Kindly can anyone tell me what is the parameter in Nokia that let the MEs to go to 2G in CSFB calls directly?
I mean not even read the 3G (cause serving site is 4G/2G)…
Is it from System info parameters or what?
Need to eliminate 3G there because its coming from little far sites.
Atbarawi
1
Related Topics
Disable ue-not-involved Relocation Type | 0 | 502 | March 14, 2021 | |
Reduce CS Fallback (4G-2G) time in Nokia system | 5 | 2433 | January 30, 2020 | |
UE switching to much from 3G to 2G | 1 | 381 | June 6, 2021 | |
What parameter in Nokia 3G limits access by distance of a UE | 3 | 2169 | August 21, 2017 | |
3G multi-rab throughput | 1 | 954 | December 18, 2021 | |
What parameter in Huawei 3G limits service by distance | 1 | 1101 | October 25, 2018 | |
Parameters/Features that prevents ENDC or release ENDC | 1 | 647 | April 2, 2021 | |
Parameter to Forbid PS UTRAN HO | 3 | 359 | March 5, 2021 | |
Fix overshooting in 3.5 GHz sites | 2 | 510 | February 20, 2021 | |
Block the UE to latch on 4G from RAN node end | 3 | 458 | May 15, 2021 |
