Hi Friends,
We know 3GPP takes utmost care to make sure that 3GPP releases are backward compatible.
Have you seen or faced issues such as latest UE’s (Ex Rel 15) causing problems at eNodeB which has support only for 3GPP Rel 10 or Rel 8?
gkreddy
1
Related Topics
Are there any issues if MME is release 9 and NodeB is release 10? | 2 | 986 | August 17, 2017 | |
What are the probable issues for a UE latched to 5G with no throughput? | 1 | 266 | August 31, 2023 | |
Is there any database of commercial UEs and Networks supporting NR Rel 16 & 17? | 1 | 204 | December 18, 2023 | |
5G Throughput Speed on certain CPE devices | 2 | 601 | June 3, 2022 | |
What is the impact of having a Redundant eNodeB ID in 4G network? | 6 | 130 | June 13, 2024 | |
Is 2-step RACH specific to release 16? And how could I consistently use it? | 0 | 12 | August 15, 2024 | |
Does UE contains nr-RadioBearerConfig1-r15 after sgnb released | 0 | 758 | April 13, 2022 | |
Lot of RTWP errors after upgrades | 2 | 565 | March 16, 2022 | |
5G NR leg not being set up when UE in floating mode | 3 | 888 | March 11, 2021 | |
SCG Failure due to rlx-MaxNumberRetx (thermal issue) | 2 | 565 | July 24, 2021 |
