The first step in 5G Standalone (SA) call processing is synchronization between UE and gNB.
The synchronization process is divided into Downlink synchronization and Uplink synchronization.
Downlink synchronization precedes Uplink synchronization.
Downlink Synchronization:
- UE performs cell search for synchronization signals.
- Primary Synchronization Signal (PSS) and Secondary Synchronization Signal (SSS) are acquired.
- PSS and SSS help identify the cell and synchronize UE’s timing.
Uplink Synchronization:
- Uplink synchronization achieved through RACH Process.
- Random Access Channel (RACH) is used for initial uplink synchronization.
- UE transmits a randomly chosen preamble via RACH.
- gNB detects preamble and responds with timing adjustment.
- This process aligns UE’s transmission timing with gNB for efficient communication.
RRC Connection Establishment:
- Post synchronization, UE initiates Radio Resource Control (RRC) connection procedure.
- UE sends RRCSetupRequest message to gNB.
· gNB responds with RRCSetup message containing vital configuration details. - Configuration information facilitates UE’s access to network resources.
Registration Request:
- After successful RRC connection establishment,
- UE sends Registration Request message to Core Network (AMF).
- Purpose is to register with 5G network.
- Message includes significant details:
UE’s security credentials
UE’s network capability.
Note: It is a simplified call processing/Signaling flow of SA Initial Attach process[PART1], if you want to understand the in-depth flow analysis then i do recommend to refer Event Helix, Links mentioned in comment section.
LinkedIn:
