Hello experts,
How many SRs and CSI reports can be multiplexed on same resource in UL? For example up to how many UEs can be multiplexed on same SR resource? And how many UEs can be multiplexed on same resources for HARQ feedback?
H
new_moon
1
Related Topics
How to multiplex bits in PUCCH when HARQ +SR + CSI all 3 need to send? | 1 | 414 | September 27, 2022 | |
UCI over PUCCH or PUSCH? | 2 | 1871 | March 4, 2023 | |
How many UEs can be multiplexed in PUCCH Format 1 in 5G? | 4 | 368 | July 30, 2024 | |
How many UEs can use U-slots with periodic CSIs configuration? | 11 | 272 | May 27, 2023 | |
Does UEs can use the same SR to ask for resources in the UL? | 1 | 305 | October 8, 2022 | |
Which PUCCH formats support SR transmission? | 3 | 420 | July 28, 2022 | |
Maximum number of UEs that are in RRC connected state simultaneously | 4 | 1036 | July 10, 2023 | |
How to check how many CSI RS ports UE are able to support? | 5 | 1015 | October 21, 2020 | |
Is there any IE limiting the CSI reports UE can send? | 6 | 1181 | July 8, 2021 | |
Can UE (REL-15) send ACK/NACK on two consecutive slots in PUCCH? | 0 | 318 | November 28, 2022 |
