Hi friends,
Would like to check below flow and understanding.
Let me know if any change required for LTE:
TBS from Mac layer --> crc added --> codeword --> coding applied --> interleaving/rate matching --> modulation applied --> resource mapping/MIMO --> ofdma signal generation.
Now coding applied is as below for LTE:
Turbo coding for ul-sch, dl-sch, pch.
Convolution coding only for BCH.
Block coding for pfcich.
Need to discuss type of rate matching in detail used for LTE.
What is it usage?
Is rate matching and interleaving same terminology?
Which entity allocate EPS and DRD ID is it P-GW?
Rate matching is different from interleaving.
Interleaving is spreading the data in time.
Rate mtaching and puncturing means filling in the data according to TB size.
Thanks, do you mean PCRF allocates ID?
Like one PDU having multiple QoS session and per UE we can have 16 DRB mapped with QoS session?
Any idea for limit of DRB linked with EPS ID? Is it the same?
