Hi Guys,
Quick question: anyone knows where we can read the LTE transmission mode from a DT log?
I mean which message?
Hi Guys,
Check L3 msg: RRC signalling;DL-CCCH:rrc connection setup (here is tx mode).
Just after rrc req and sib1 msg.
Which Drive Test Tool, you have?
In Probe you can view TM2, TM3 in Radio Parameters.
Tems, Nemo.
We have activated a mMIMO with TM switch between TM3 and TM8.
I want to plot the switch against the SINR variation.
It is present in L3 msg “RRC Connection Reconfiguration (DL-DCCH)”
