Hi experts,
What are the recommended values for the DL t-Reordering timer at the PDCP level and the t-Reassembly timer at the RLC DL level for VoNR bearers?
Hi experts,
For VoNR bearers, the recommended values are:
Since the voice bearer is UM, I believe it might be better to set the t-Reassembly timer slightly higher, perhaps around 60ms.
As for the PDCP timer, could a 200ms setting potentially cause unnecessary delays for the TCP layer?
VoNR can be either AM or UM, unlike VoLTE, which can only be UM.
In my case, it is UM.
Samsung uses the values mentioned above, but you can try different values.
VoLTE can also be AM.
I’m not sure if any operator uses AM for VoLTE.
For QCI5.
JIO in India have used it. For QCI-1.
It works well in cells with high losses, but it introduces some delay and high overhead.
In the early deployment of VoLTE, the packet loss rate was very high, which is why they used…
Normally no AM for QCI1.
