Need your help to reduce the CCE Failure Rate in low users/low utilized cells (LTE) in Huawei system.
Can you suggest any parameters to be optimised?
Hi, you should check:
What is utilization % for agg level 1, 2, 4, 8?
CCE power adjusted?
Automatic option?
Automatic.
Hi @Manoj_deka, As you mentioned low utilized cells which indicates obviously capacity and congestion is not an issue.
You may try PDCCH power enhanced feature, this also helps in PDCCH coverage boost poor coverage and quality
You may try feature related to PDCCH link adaptation.
