Reduce cdrx on latency, for SA NR cell
Hello,
Userplane latency is 15 ms when cdrx OFF.
Userplane latency is 65 ms when cdrx ON.
Can you suggest how to reduce cdrx on latency, for SA NR cell?
Inactivity timer, on duration timer fine tuning.
Actually those are fixed.
Ok, then only switch there to make it ON/OFF correct.
How do you measure latency?
Can you please tell me how we can check CDRX OFF
CDRX ON with QXDM ??
with [ 0xB890 ] NR5G MAC CDRX Event info I know but not sure how to check all this message Can you please provide some details ?
