Dear Experts,
Any solutions to reduce PRB/Increase throughput of a congested Cell if Traffic offloading is not possible (neigbor cells are also highly utilized).
As addition of extra band is not that easy, or new capacity sites will be installed in a longer time.
Its ZTE LR17.
Some power reduction was done previously to reduce PRB but that does not prove to be a healthy solution, Traffic Lost was observed
Please Check Data Volume/Connected User>If Both are Less, this means that the users are in bad RF conditions.
You can Check value in Residual BLER @eNB end.
You can implement SFN solution if the other sectors of the site are not so highly utilized.
We use it in stadiums with good results.
Single frequency network feature between ie sectors 1 and 2 if one of them is highly utilized and the second has lower utilization/users.
Dear Rubao, Can i use SFN feature to balance traffic of Split sector. Actually i have in Huawei system L2100 Split sector one cell have high traffic and other have less traffic. Please help.
try to improve your spectral efficiency, regarding improvement of CQI, CCE Utilization, reducing % CFI=3 (if you upgrade to LR20 on ZTE it’s possible to use CFI enhancement feature to reduce CFI=3 utilization)
