Dear Experts.
What is the reason for Regular RSSI Issues in Network?
It come for some time and again will be back to normal.
Can we fix this issue?
RSSI going towards High or Low?
Going High.
Considering >-105 as RSSI Impacted.
All over network or specific site?
In some specific sites.
Probably some HW issues, ALD alarms, Mast misconfigurations.
Propagation loss.
How can we overcome this?
If it come for some time and then goes normal. there may be chance for any external device which is switched on then RSSI impacted and once it off everything normal.
To identify the external device, you have to use scanner drive in the same time when RSSI Impacted. It will help you to find the external device.
You can connect me on WhatsApp +91-7259704040 for more details.
