Resource block is 180khz with subcarrier spacing of 15khz whereas it is 360khz with 30khz subcarrier spacing.
How this thing impact on the improved latency level? How the tcp/ip packets gets effected due to this so we get reduced latency.
O.B
2
In ofdm, the symbol duration = 1/subcarrier spacing.
Increasing SCS decreases symbol duration and hence slot duration and latency improves (given all other factors are fixed)
Related Topics
5G/TCP/IP packets | 0 | 335 | June 14, 2021 | |
Lower latency in 4G/5G than in 2G/3G | 3 | 790 | April 6, 2020 | |
Modulation scheme to reduce latency in 5G NSA | 1 | 452 | June 11, 2021 | |
What are the factors affecting user plane latency in 5G NR SA? | 5 | 908 | July 24, 2021 | |
Any network in NR using 15 kHz sub carrier spacing globally? | 4 | 423 | June 7, 2021 | |
Change of SCS from 30 kHz to 60 kHz | 4 | 280 | February 16, 2023 | |
SS-PBCH Block Power impact in Throughput | 1 | 1784 | April 23, 2021 | |
Increased HARQ process in NR | 1 | 664 | May 21, 2021 | |
Reduce cdrx on latency, for SA NR cell | 5 | 761 | July 21, 2021 | |
Frame offset | 0 | 660 | December 13, 2020 |
