ROP file time setting
Hello Experts,
I have a question , how to set the ROP files time interval in the BSC? could you please give me the command to check the current timing of the ROP files and to set the ROP files intervals to 15 minutes.
At the moment the files are coming hourly but we need to set it for 15 minutes.
BR//
Hi, @Mani, from BSC (APG) side it can be configured to 5 or 15 minutes stmotd:
-b brp
Basic Recording Period (BRP)
The option is used to select BRP of the counters belonging to the selected Object Type(s).
Use one of the following values:
5
BRP of 5 minutes
The BRP value of 5 minutes will be the interval between one collection of counters and the next collection of the same counters.
15
BRP of 15 minutes
The BRP value of 15 minutes will be the interval between one collection of counters and the next collection of the same counters.
Iā€™m pretty sure your BSCs have configured to 15 minutes (check with stmotls in APG).
1 hour rop collection configured in ENM statistical Subscription, so you need to change there.
Thank you so much, Yes I checked in the BSC and it is showing all the ROP in 15 minutes. I will try to change in the OSS.
BR//
