Routing and switching
Routing & Switching steps to follow in
Network Fundamentals
Compare and contrast OSI and TCP/IP models
Compare and contrast TCP and UDP protocols
Describe the impact of infrastructure components in an enterprise network
Describe the effects of cloud resources on enterprise network architecture
Compare and contrast collapsed core and three-tier architectures
Compare and contrast network topologies
Select the appropriate cabling type based on implementation requirements
Apply troubleshooting methodologies to resolve problems
Configure, verify, and troubleshoot IPv4 addressing and subnetting
Compare and contrast IPv4 address types
Describe the need for private IPv4 addressing
Identify the appropriate IPv6 addressing scheme to satisfy addressing requirements in a
LAN/WAN environment
Configure, verify, and troubleshoot IPv6 addressing
Configure and verify IPv6 Stateless Address Auto Configuration
Compare and contrast IPv6 address types
LAN Switching Technologies
Interpret Ethernet frame format
Troubleshoot interface and cable issues (collisions, errors, duplex, speed)
Configure, verify, and troubleshoot VLANs (normal/extended range) spanning multiple
switches
Configure, verify, and troubleshoot interswitch connectivity
Configure, verify, and troubleshoot STP protocols
Configure and verify Layer 2 protocols
Configure, verify, and troubleshoot (Layer 2/Layer 3) EtherChannel
Routing Technologies
Describe the routing concepts
Describe how a routing table is populated by different routing information sources
Configure, verify, and troubleshoot inter-VLAN routing
Compare and contrast static routing and dynamic routing
Compare and contrast distance vector and link state routing protocols
Compare and contrast interior and exterior routing protocols
Configure, verify, and troubleshoot IPv4 and IPv6 static routing
WAN Technologies
Configure and verify PPP and MLPPP on WAN interfaces using local authentication
Configure, verify, and troubleshoot PPPoE client-side interfaces using local
authentication
Configure, verify, and troubleshoot GRE tunnel connectivity
Describe WAN topology options
Configure and verify single-homed branch connectivity
Describe basic QoS concepts
Infrastructure Services
Describe DNS lookup operation
Troubleshoot client connectivity issues involving DNS
Configure and verify DHCP on a router (excluding static reservations)
Troubleshoot client- and router-based DHCP connectivity issues
Configure, verify, and troubleshoot basic HSRP
Configure, verify, and troubleshoot inside source NAT
Configure and verify NTP operating in a client/server mode
Infrastructure Security
Configure, verify, and troubleshoot port security
Describe common access layer threat mitigation techniques
Verify ACLs using the APIC-EM Path Trace ACL Analysis tool
Configure, verify, and troubleshoot basic device hardening
Describe device security using AAA with TACACS+ and RADIUS
Infrastructure Management
Troubleshoot network connectivity issues using ICMP echo-based IP SLA
Configure and verify device management
Configure and verify initial device configuration
Perform device maintenance
Use Cisco IOS tools to troubleshoot and resolve problems
Describe network programmability in enterprise network architecture
