Hi Team,
Getting RRC setup failure multiple times in cluster drive because of CT timer expired.
Anyone having any view or ideas? Or faced similar issue?
Hi Team,
What is CT resolution timer?
Contention resolution timer.
Increase the max harq DL retx or there is strong Dl interference, UE can not decode msg4.
As msg1/2 success you don’t have cell radius issue as I do believe.
Yes it is coming for msg4 only
You are in the right direction
Because of this Reach failure occuring leading to MO/MT RrC setup success rate.
please elaborate.
Overlapping / Overshooting, PCI clashes, PIM, or external interference.
Further you can check this post: Main cause for downlink interference in LTE - #3 by Victanand_K_S
