Hi guys, one question.
For RRC signaling based BWP switch in case of TDD system, if I mention just DL BWP ID, then UL BWP will also changed automatically, as TDD is unpaired system?
Is this the correct understanding?
Yes, BWP in TDD for both UL and DL will be changed simultaneously.
Actually, both should have the same BWP-ID.
Related Topics
How many BWP defined from gNB to UE? | 80 | 295 | September 26, 2024 | |
How BWP is defined in 5G | 0 | 591 | November 1, 2021 | |
BWP (Bandwidth Part) parameters | 0 | 312 | August 27, 2023 | |
Does anyone know how to check behavior of DCI based BWP switching on QXDM? | 6 | 492 | October 23, 2022 | |
Can active BWPs for different UEs overlap? | 0 | 636 | April 20, 2022 | |
Active BWPs in FDD for 2CC | 1 | 18 | August 11, 2024 | |
What happens if two 5G neighbor sites are configured with different tdduldlpattern 0 and 1? | 2 | 331 | December 14, 2022 | |
5G BWP doubts regarding the call flow | 0 | 370 | October 22, 2021 | |
UL Semi Persistent Scheduling | 1 | 578 | February 4, 2020 | |
Does 5G NR (both FDD and TDD) have unified SSB structure? | 0 | 1014 | March 13, 2022 |
