Hello dear Experts.
Could you clarify please next thing:
Comparing RRU with 2T2R with MIMO2x2
With RRU with 4T4R with MIMO2x2 feature
Does it mean that second RRU would give better coverage or throughput?
lf so, how much?
Any suggestions?
Hello dear Experts.
lf so, how much?
Any suggestions?
Hi Dear.
4T4R High throughput you have because you can send 4 different data in each port, so throughout will improve.
Coverage is related to power per port.
Better coverage and same throughput.
Coverage also means covering the black holes.
This is a very common misunderstanding.
If power of 2T2R per port is same as 4T4R, coverage will not be impacted.
Coverage is mostly challenged on Uplink (not Downlink).
So you achieve better coverage per site by having higher gain antennas and more receivers.
So 2T4R has better coverage than 2T2R.
They both have MIMO2x2. Difference is only about number of antenna ports.
Why?
Yes, I thought the question was MIMO 4T4R and 2T2R.
Many engineers think that increasing the Downlink output power (Watt) results in increased the coverage.
However, as I said, the problem is usually on Uplink.
Because mobile networks are supposed to be 2-way communication.
So the base station may be able to boost its output to 20 or 40W power - but that does not increase the output of the phone (usually around 1 to 2W).
Uplink is almost always a bottleneckđ
Now⌠what if next configuration:
RRU 2T2R MIMO2x2.
Power per port 20W.
RRU 4T4R MIMO2x2.
Power per port 10W.
So, total RRU power in both cases are the same.
Coverage and throughput the same?
No diversity gain resulting in better coverage and throughput ?
Hi, could you clarify what do you mean by âRRU 4T4R MIMO2x2â?
Are you using only 2 port of 4T4R RRU?
As I understand you are using all 4 ports, so should be MIMO4x4.
As I know, not always RRU with 4 RF ports means MIMO4x4 capability.
Yes, he can do that.
4T4R throughput is going to be better.
Thatâs true!
It even create Downlink and Uplink imbalance and UE lost due to poor coverage starts increasing.
Any specific vendors?
No, will not.
Coverage will be better for 2T2R.
Why not?
Secret vendors doesnât matter.
