Hello dear Experts!
Let’s imagine next situation:
Our RRU has -102 dBm receiver sensitivity per port.
Huawei / Ericsson / Nokia RRU has - 106 dBm receiver sensitivity per port.
2 questions:
Does it mean that our RRU will provide in 4 dB shorter UL coverage?
Power control: Po = -74; alpha = 0.7.
Should I set up Po=-100; alpha = 1 to improve cell edge UE Throughput?
Yes.
Yes, but you should also account for multiple antennas.
If Ericsson has 32TR, then total receiver sensitivity will be -106 -15 = -121 dBm.
If you have 8TR then your Rx sensitivity will be -102 -9 = -111 dBm
Hi dear, thanks for reply…
But let’s think we compare RRUs with only 2 RF ports.
Then, you can increase P0 by 4 dB from -74 to -70 dBm.
P0 will absurb the Rx sensitivity .
Why do you want to change alpha?
I am thinking about improving cell edge KPIs.
Our base stations is in rural areas so I think setting up alpha = 1 I will improve cell edge UE KPIs as there is no interference.
