RSRP: Coverage (Network KPI -17)
Reference Signal Received Power (RSRP) - It is a critical metric used to assess the coverage of a 4G/5G mobile network.
This indicator measures the linear average over the power contributions of the resource elements that carry cell specific reference signals within the considered measurement frequency bandwidth.
The following classifications outline RSRP values and their corresponding signal penetration capabilities:
  • Excellent (-75 dBm or better): Optimal for indoor coverage.
  • Good (-85 to -75 dBm): Reliable performance in various environments.
  • Fair (-95 to -85 dBm): Adequate for in-car use.
  • Weak (-105 to -95 dBm): Limited outdoor connectivity.
  • Poor (< -115 dBm): Signal is generally unusable.
Understanding RSRP helps in optimizing network performance and enhancing user experience.
