Hi Everyone.
If you are an Ericsson expert in here:
I want to run a script on Ericsson EvoRNC.
I want to know where to add the script and how to run it.
Please assist with ideas.
Hi Everyone.
Via AMOS or ENM in XML.
As already said, you can do it via AMOS.
Prepare your script, put it in a directory then run it.
Hi, XML in ENM, *.mos in amos/moshell, *.mo in ElementManager GUI.
Thanks a lot.
Which directory, please?
For instance, the file is test.xml, which directory should I save it?
And which command should I use to run this script?
Open ENM GUI in browser → bulk import → new plan
