S20FE 5G calls not being disconnected until other part disconnect
Dear All
After latest upgrade of 1st Mar 22, on S20FE 5G handsets installed, some users are facing issues with their calls not being disconnected until other party disconnects.
Moreover, no Auto recording response is being placed by the keypad during the call.
Anyone else heard about same issue?
I have the same phone, I luckily did not install that upgrade till now.
Any fix to this issue known?
Hello,
Have you seen the SIP log signalling? I assume it is a VoLTE call. If you can, try to replicate the issue. Is easy to do logs with any Samsung. There you can have a clue about what could be.
Cheers
