Secondary RAT message usage report in ENDC
Hi all,
In ENDC, there is a process message called Secondary RAT Message Usage Report. Could someone please explain it in detail? Specifically:
  • Is it mandatory or optional?
  • Where does it appear in the call flow?
Thank you in advance.
SRDUR (Secondary data usage report) is a optional procedure depends on gNB implementation.
This procedure will be enabled at NgB so that gNB should send the Data usage of an UE while release the UE.
The master eNodeB has parameters that can enable this procedure.
As per 3GPP, it measures UE data at the PDCP layer.
If someone could share a detailed flow or diagram, it would make it easier to understand where and how this procedure fits in.
