Question: a fiend is trying to setup a lab to test Massive MIMO, amongst other things.
The handsets should sit within shielded boxes and the operator elsewhere.
He needs to control the handset remotely, also obtain logs.
He is assuming only such as TEMS or NEMO can do it, through a script. Is this right?
Is there other tool that cand run scripts and collect logs remotely?
Apart from Probe of Huawei or QXDM of Qualcomm?
Which one is better in your opinion?
He is also dealing with anechoic chamber…
Yes, you can use Huawei Probre (PHU). But you sadi apart from it.
Maybe others can suggest other than TEMS, NEMO, PHU and QXDM.
