I am happy to share the top articles of ShareTechNote in 2022 for 5G NR, 4G LTE and Engineering Math.
Note: there are much more content (other technologies), find out there: Sharetechnote
5G/NR
- 5G/NR - Frame Structure 5G/NR - Frame Structure
- 5G/NR - Initial Access / RACH 5G/NR - Initial Access / RACH
- 5G/NR - DCI 5G/NR - DCI
- 5G/NR - SS Block 5G/NR - SS Block
- 5G/NR - MIB / SIB 5G/NR - MIB / SIB
- 5G/NR - FR/Operating Bandwidth 5G/NR - FR/Operating Bandwidth
- 5G/NR - CSI Report 5G/NR - CSI Report
- 5G/NR - Carrier Bandwith Part 5G/NR - Carrier Bandwith Part
- 5G/NR - CSI RS 5G/NR - CSI RS
- 5G/NR - CSI RS Codebook 5G/NR - CSI RS Codebook
4G / LTE
- 4G/LTE - RACH 4G/LTE - RACH
- 4G/LTE - Frame Structure 4G/LTE - Frame Structure
- 4G/LTE - DCI 4G/LTE - DCI
- 4G/LTE - Measurement 4G/LTE - Measurement
- 4G/LTE - Protocol Stack 4G/LTE - Protocol Stack
- 4G/LTE - RRC 4G/LTE - RRC
- 4G/LTE - Basic Procedure Quick Reference 4G/LTE - Basic Procedure Quick Reference
- 4G/LTE - Power Control 4G/LTE - Power Control
- 4G/LTE - DRX 4G/LTE - DRX
Engineering Math
- Engineering Math - Differential Equation - Spring Mass Model Engineering Math - Differential Equation - Spring Mass Model
- Engineering Math - Differential Equation - Electric Circuit Engineering Math - Differential Equation - Electric Circuit
- Engineering Math - Differential Equation - Converting High Order Differential Equation into First Order Simultaneous Differential Equation Engineering Math - Differential Equation - Converting High Order Differential Equation into First Order Simultaneous Differential Equation
- Engineering Math - Matrix - Inner Product/Dot Product Engineering Math - Matrix - Inner Product/Dot Product
- Engineering Math - Differential Equation - Cooling Engineering Math - Differential Equation - Cooling
- Engineering Math - Differential Equation - State Space Modeling Engineering Math - Differential Equation - State Space Modeling
- Engineering Math - Matrix - Stiffness Matrix Engineering Math - Matrix - Stiffness Matrix
- Engineering Math - Matrix - Eigenvector and Eigenvalue Engineering Math - Matrix - Eigenvector and Eigenvalue
- Engineering Math - Differential Equation - Mixing Model Engineering Math - Differential Equation - Mixing Model
- Engineering Math - Matrix - Overview Engineering Math - Matrix - Overview
