Dear experts,
When measuring SINR using scanner, which one is best to asses nw condition.
Reference signal based or PSS/SSS based?
Thanks.
I think you have to go with PSS/SSS SINR.
You’ll only have DMRS when you’re in connected mode.
scanners are only used in idle mode, not connected mode.
5G SS-SINR is SSS measurement, not PSS.
But you need to check whether your scanner supports SS-SINR. I see some UE only support SS-RSRP, not SS-SINR.
