Hi all,
what happens if a callee doesn’t answer a call (after 180 ringing)?
After 180 ringing if the callee doesn’t answer, it is normal to receive a 480 as well or no other message response are generated?
auato
1
Related Topics
What will happen if UE don't read the paging message? | 3 | 582 | April 8, 2022 | |
CFB call flow scenario in VoLTE if CFB at B is configured with A Number | 0 | 361 | June 6, 2023 | |
What happens If SGW does not send end marker packet? | 0 | 875 | December 7, 2021 | |
If third party ims reg fail or there is no response from the server what will happen? | 1 | 469 | March 30, 2021 | |
Diameter time between request and answer | 0 | 186 | January 23, 2024 | |
VoLTE Drop Calls with SIP Code 8003 Despite Excellent Radio Conditions | 33 | 600 | October 20, 2024 | |
Expected time between a EPC/5GS message request and response | 0 | 228 | November 30, 2023 | |
Difference in Bearer Assignment between Normal and Emergency VoLTE calls: AA-Request only triggered in Emergency Calls | 0 | 71 | October 4, 2024 | |
What cell shall do when it recieves that PDU AMBR value? | 3 | 410 | September 19, 2023 | |
S20FE 5G calls not being disconnected until other part disconnect | 1 | 441 | April 13, 2022 |
