Hi All.
Can any one explain Smallpacket MCS reduction feature in 5G?
When a single RBG is allocated for small packets, there will be lots of padding bits. So this feature replaces padding by coding bits through MCS reduction to increase robustness without additional resources
What is advantage of Code Block Group based method in 5G? | 1 | 594 | April 27, 2021 | |
RoHC for VoLTE and Cell Coverage | 0 | 930 | May 18, 2022 | |
Resource block latency impact | 1 | 464 | June 21, 2021 | |
Lower latency in 4G/5G than in 2G/3G | 3 | 791 | April 6, 2020 | |
What specific inputs does the MAC scheduler consider when allocating downlink resources? | 15 | 114 | October 17, 2024 | |
5G NR mapping CQI to MCS | 2 | 254 | October 19, 2024 | |
DL HARQ MCS Adaptation while keeping TBS same in LTE | 3 | 325 | June 5, 2024 | |
BWP (Bandwidth Part) parameters | 0 | 316 | August 27, 2023 | |
5G/TCP/IP packets | 0 | 335 | June 14, 2021 | |
Closed Access Group in 5G | 0 | 805 | October 30, 2021 |
