Hello Experts,
How can I improve Mute Call in Volte?
Hello Experts,
Sure, give me more details
Check first UL/DL mute rate, which band
check the rrc reestablishment if it high
Check RTP Packet lost on the SBG. Check the Tx packet lost between enodeb and the SGW.
Hi All.
How can we capture mute VoLTE Call?
Vendor Huawei.
And if possible, resolution/suggestions required at Radio end.
Mostly muting occurs due to handovers and it may occur due to early handovers or too lte handovers find out these two stats from the cell affected and try to fix the cell to cell HO using cio
Can you suggest which all the parameter need to check and what is MO name and threshold to be set.
Can you share MO details.
