In case of codebook based transmission how SRS transmission happens at UE based on No of SRS ports = 1 or 2 or 4 configured. Also how UE will decide on which antenna ports it has to transmit SRS.
Please help me with this.
If SRS is configured with the number of ports set to 1, UE transmits SRS signal on only one port at a time. If SRS is configured with the number of ports set to 2, UE transmits SRS signal corresponding to 2 ports at a time, like in MIMO operation.
Mapping between each SRS resource and the corresponding port set is up to the UE vendor. The network doesn’t need to know this info.
Thanks @pradeep.
For example When we have only 1 srs resource configured with No of srs ports = 2 and if UE has four antenna ports then on which 2 antenna ports SRS should be transmitted is up to UE vendor.
Am I correct?
Yes… that’s right. But if that one SRS resource is codebook type, UE will use the same ports it is using for pusch transmission.
Thanks pradeep
